Toro CCR Powerlite
Old 02-12-09, 01:38 PM
Toro CCR Powerlite
I have recently cleaned the carburetor on my toro ccr powerlite. The problem is its leaking throught a small hole about 1/4 of the way down from the top, i was thinking it was a relief hole, but was not sure, any pics of the carb would be greatly appreciated
Old 02-12-09, 03:50 PM
Toro CCR Powerlite
Hey there. The hole that's leaking is the "vent" hole. When you cleaned the carb, I'm assuming you removed the bowl, float, and inlet needle. Check the inlet needle and gasket (there's a tiny o-ring inside the inlet to ensure that it can effectively seal out fuel when closed (in the up position). Also, not sure if your model has a check valve between the primer bulb and connection to the carb (on the primer tubing). Check and blow out with compressed air to make sure it's not clogged or installed backwards.
