Honda EX650
Honda EX650
I'm working on a friends generator , history is as he tells it only 20 hours before he let it sit for a year . I removed and cleaned the fuel tank , disassembled the carb and cleaned it all out . Now I've found there is no cylinder compression at all . Is it possible the valves or rings are gummed up ? Should I do a leakdown test ?
Have you pulled the valve cover to see if a valve is stuck? A leakdown test will show you if this is the case but I think you're gonna have to pull the valve cover anyway, even if it's not the valves sticking...so pull it and see.
Well I installed the new headgasket , torqued the head . It starts first pull every time . I warmed it up and changed the oil and ran it for 15 minutes , set the carb , no leaks ! Done deal . Great site you have here , I'll be spending more time here in the future . Thanks .Beer 4U2
