Pressure washer problems
EAGLE-1's Avatar
02-16-09, 03:37 PM   #1
I have a craftsman pressure washer with a problem. It is about five years old,model 580 768310, with a 6.25 HP Tecumsh engine. My problem just started, motor runs fine,but when I pull the trigger to activate the high pressure the engine does not rev up. I can mess with the linkage on the carb and it will rev and maintain until I release the trigger then the motor drops back to idle. I repeated this cycle
numerous times but could not get the unit to operate as it had
previously. I ran the Washer for about 2 hrs, everything else worked fine but his problem never got better.
cheese's Avatar
GA
02-16-09, 09:08 PM   #2
I'd say the unloader valve in the pump is probably sticking. You'll have to take it out, clean and lube it, and reassemble.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
