AL
02-17-09, 03:25 PM
Need valve settings
I've got a Briggs: M-12H802, T-2328 B1, C-00022956 and I've ground and seated the valves but I can't find the clearances for this model. Could someone help me out with these? Also, could you tell me what position the crankshaft is, is it TDC on the power stroke or is it somewhere before TDC? Could you tell me a web site where I can look up this information?
TX
02-17-09, 04:10 PM
You can find engine specifications for Briggs engines at their website, here is the link for the check chart. The Specs for your engine is located 6 down from the top under the L Head section.
http://www4.briggsandstratton.com/mi...art_ms3992.pdf
Set the valves at 1/4" past TDC on the compression stroke
Best of Luck...
Best of Luck...
