Craftsman Leaf Blower
Old 02-21-09, 03:37 PM
First time poster. My blower slowly started giving me problems last season so after ruling out carb, gas, air, plug issues, I gave it to my local repairman to diagnose. Said the ring (just one) needed replaced, but he wanted more than I thought it was worth so I had him get me the ring and I'd do it myself. Hey, I've rebuilt a couple of Fords in my day. So after dismantling and with my $5 ring (just one) in hand I find the old ring stuck, frozen, locked, mated in it's grove. This thing looks so delicate I'm afraid to force it. Any advice on how to separate these two?
Old 02-21-09, 08:13 PM
hopkinsr2's Avatar
If the old ring is stuck that bad to the piston, have a close look @ the piston & the bore of the cylinder for scoring. This is usually caused from excess heat or carbon from too much oil in the fuel. If carbon, soak the piston in a carb cleaner bath to dissolve it. Check the crank seals & make sure the carb isn"t causing a lean condition, as well.. Good luck, Roger
Trackbacks are On
Pingbacks are On
Refbacks are On
