2000 yamaha grizzly,weak or no spark
yamahog's Avatar
02-27-09, 03:08 PM   #1
when i crank over it has no spark,if i put charger on it ,it will have spark but weak & when it fires it blows the carb off the head,is that because its loading up and finally fires when it gets to the weak spark?I didnt swap the stator,should i bother or just buy a new one
marbobj's Avatar
IA
02-27-09, 04:06 PM   #2
Can you start it with the pull rope?
hopkinsr2's Avatar
Non-US
02-27-09, 05:00 PM   #3
Have you tried a new sparkplug yet?? Also the sparkplug cap has a resistor in it that goes bad (kinda common if H2O is involved in your rides). Try a plug & a cap (they just screw on the end of the plug wire) & that may be all you need..Good Luck, Roger
