Tecumseh Gas Leak
Tecumseh Gas Leak
I have a MTD Snow Blower with a Techumseh HSK600 1627S engine. It runs good but, I have gas leaking from the main air bleed when not in use. I have replaced the carb needle, seat and float. Double checked the the float height at 11/64" this weekend and it still leaks. Any ideas?
Tecumseh engines are notoriuos for developing pin holes in the floats. I keep 5 in stock in my shop just for that reason. Remove the float and set it in a bowl of water. If it floats close to level(needle end will sink a little lower as that end is heavier) you are ok. If not, you need a new float. About $5 for a new float.
I would check to make sure the seat is seated all the way.
Remove the seat using a dentist pick, then, using a Q-tip sprayed with carb cleaner, clean the hole where the seat goes.
If the seat is not properly seated, gas can leak around the seat.
Was the seat properly installed? The groove needs to face down. I find the job easier with a pin punch slightly smaller than the bore and a spritz of WD40 or something similar. After install, make sure the little beggar is perfectly square in the bore.
Leak Fixed
Ok here is the story. I finally got to work on the thing last night. As it turns out the compressed air I used to clear the carb,pushed the seat down enough to make the carb leak. Disassembled the carb, cleaned the seat bore and reinstalled with a drop of SAE30 oil. Runs good no leaks. Thanks for the help.
