Primer bulb
Jack B.'s Avatar
AL
03-05-09, 04:30 AM   #1
Primer bulb
I've got a walk/behind in with a Briggs engine m-12H802, t-2328. I have replaced the carburetor but the primer system is giving me fits. How exactly does the primer system operate? I've looked in all my Briggs manuals and I can't find any detailed information. I've even replaced the primer bulb. If I spray some fuel into the air filter opening it will start and run fine. What I need to know is just what happens whenever I press and release the bulb. I can't see if it's operating because there is a piece of metal sticking up in front of the air filter side opening. Whenever I press the bulb isn't it suppose to put a little pressure on the fuel in the bowl and spray some fuel into the throat of the carburetor?
indypower's Avatar
NH
03-05-09, 06:06 AM   #2
Remove the air filter, then remove the housing form the carb.
On the back side of the housing, you will see the channel for the primer. Clean it with spray carb cleaner and blow it out completely with compressed air.
This design seems to be prone to getting plugged up due to its close proxcemity to the flying dust & dirt.
hopkinsr2's Avatar
Non-US
03-05-09, 03:20 PM   #3
Also make sure to replace the gasket between the filter housing & the carb. I find a lot of these torn or damaged & cause the trouble you describe.. Roger
cheese's Avatar
GA
03-05-09, 06:22 PM   #4
I agree with Hopkins...generally primer problems with that style carb are caused by a bad gasket between the carb and air filter cover. The primer shoots through a passage on the back of the cover that is supposed to be sealed against the carb, but if the gasket is hurt the small amount of air pushed through there leaks out instead of pressurizing the bowl.
Also, if the bowl gasket is damaged or missing it may not prime right.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Jack B.'s Avatar
AL
03-05-09, 09:13 PM   #5
Thanks fellows for the advice. The problem turned out to be exactly what you were talking about. I had to clean the small screen behind the primer bulb and also added some permatex to the gasket between the carburetor and air filter. Thanks!
