Homelite chain saw clutch failure
Old 03-14-09, 08:31 PM
I have a Homelite 10 inch chain saw, about 30 years old. The engine runs, but the clutch will not drive the chain. The clutch is held in place by a spring steel keeper. I have another saw that I can cannibalize to repair it, but don't know how to get the keeper out. How do I repair it?
Old 03-14-09, 09:05 PM
cheese's Avatar
A keeper as in a snap ring? Does it have holes at the ends for snap ring pliers? I don't recall a clutch that is held in by a snap ring/clip. Most of them unscrew from the crankshaft in the same direction that the engine rotates.
Old 03-15-09, 07:50 PM
No it does not have holes in the ends, just two blunt ends that are only about 1/16 inch apart. It appears to be pretty good steel too.
Old 03-15-09, 08:23 PM
cheese's Avatar
And this is clipped onto the crankshaft, holding the clutch on?
Old 03-15-09, 09:13 PM
What is the model # or UT#?
Old 03-16-09, 09:12 AM
Yes the little clip is on the end of the shaft and holds the clutch on.
The Serial number is 781240558.
The UT number is UT 105144
Old 03-16-09, 09:41 PM
cheese's Avatar
Ok, that is an E-ring. You should be able to put a thin screwdriver between the ring and the crankshaft, turn the screwdriver, and the ring will pull out of the groove. Watch out that you don't lose it, it will probably pop off once it gets past the widest part of the crankshaft.
Old 03-17-09, 07:42 PM
Thanks. I had to put the right size socket over the clip and pound the devil out of it, but then it came off with the screwdriver.
Old 03-18-09, 08:22 PM
cheese's Avatar
Glad you got it!
The rest of this reply is added to meet minimum character requirements...
