John deer Scotts lawn tractor?
Old 03-19-09, 02:43 PM
G
ok i have a problem with a lawn tractor im trying to sell. it startes up fine but under heavy load and high rpm it shuts down could this be due to carb problems? shut down as in stalls it has a automatic tranny with 16/42 nice mower lil older cut like nothing else could but the tractor is just stalling on me .....
Old 03-19-09, 04:23 PM
I
sounds like the carb needs cleaning. specificlly the main jet is cloggged.
Old 03-20-09, 10:18 PM
cheese's Avatar
Received 97 Votes on 90 Posts
Got any info like engine brand and model?
Old 03-21-09, 06:10 AM
G
Old 03-21-09, 06:45 AM
I
We still need an engine brand and model number.
Old 03-21-09, 09:04 PM
cheese's Avatar
....are you not at the location of the mower? Can you open the hood and get the needed info? The engine could be a number of different brands. It could be a single or twin cylinder. It could be overhead valve or flathead. It could be a 20 years old, or 10...etc...
Different engines and brands have different problem areas and are made differently. We are only grasping at straws if you give us no information to base our thinking on.
Old 03-21-09, 10:43 PM
G
ill let you all know tomorrow i have to go pick it up from my shop so i can work on it in my garage
Old 03-22-09, 12:49 PM
G
its a kholer comand cv16s 16 hp motor ill put gas threw the carb from a can on top of the carb threw the air filter way and it will start but stall as soon as i stoip the gas the carb is not letting the engine get gas now there is a electronice cilinder of some sort on the bottom of the carb if i take that off there is some kind of botton on it now when i try to start it it gets kinda hot what is this switch and could that be the reason its not starting? is there a way to bypass the selenoid?
Old 03-22-09, 03:09 PM
G
Ok update i took off the selinoid and clipped the little knob that stops the fuel from flowing since the selenoid was bad any ways now there is direct flow to the carb. i cleaned everything shot it with aiir and it still wont start like if it isnt getting fuel to the engine there is fuel in the bowl but not sending it to the motor now that selenoid gets hot if i keep it connected but even if its connected or not it still wont start what could be my problem? I have spark cus it will ignight if i manually inject fuel im getting anoyd....
Old 03-22-09, 11:10 PM
cheese's Avatar
Sounds like you still have a restriction in the carb. Use torch tip cleaners to open every jet and orifice.
