Carb Question
Old 03-24-09, 05:24 PM
W
Carb Question
Hi Guys,
I have a HSSK50 Troy Built Snow Blower and want to know the order in which the idle-jet/spring-washer -o-ring go in. Anyway does the brass washer go on after the rubber o-ring
or after the spring. Also when I try to adjust the idle it doesn't seem to change.
Many thanks to everyone here that have helped me along in repairing my snowblower. I knew nothing about small engines until this snowblower threw a rod. I ended up fixing the hole in the crankcase with quicksteel and a steel blank the size of a quarter. Now I'm just looking to get it working right so I can store it away until next winter.
Old 03-24-09, 05:44 PM
31YTech's Avatar
Well, If you get the idle adjuster installed and adjusted properly the engine may idle properly.
Put the spring on the adjuster then the brass washer then the O-ring, Install the adjuster until LIGHTLY seated closed then open it 1 1/2 turns. Start the engine and fine tune from there until the smoothest idle is reached.
Good Luck
