Chain saw kill switch
Old 03-26-09, 10:35 PM
My chain saw won't start. I've narrowed it down to the kill switch (I think!).
This is on an older Craftman chain saw. The start/stop switch appears to work by grounding out the "ignition module" when the lever is put in the stop position. I'm just guessing by the looks of the thing.
I have continuity between the kill wire on this switch and the case in both positions (start & stop). Seems to me that there should only be continuity in the stop postition.
In other words, when the switch is in the start position I should not have continuity between the case (ground) and the connection where the kill wire attaches to the ignition module.
Can anyone confirm if this is correct?
I wonder if I can even get a replacement for a Craftman saw that is 20+ yrs. old.
thanks, jon
Old 03-27-09, 12:38 AM
cheese's Avatar
Received 21 Votes on 18 Posts
Correct, you should only have continuity with it in the off position. Check for spark with the kill wire unplugged just to make sure that's the only problem.
