converting to solidstate ignition
Old 03-31-09, 11:04 AM
V
this is on a 5hp briggs. it has points and i want to convert it to solid state. i got alot of used parts......can u do this without having to buy a part? does anyone have a how to lesson on converting this motor?
Old 03-31-09, 05:09 PM
I
engine number and code please.
Old 03-31-09, 05:36 PM
A
See the heading Retrofitting An Older Ignition Armature in the link below. It gives details of converting to solid-state ignition.
The engine model number, type and code is needed to determine proper conversion kit.
How do I replace the ignition?
Old 03-31-09, 06:02 PM
C
A 5hp with points has to be a 130000 series engine. The cheapest solution is the 394970 kit. The easiest is a new armature p/n 397358.
Old 03-31-09, 08:53 PM
V
can i change the fly wheel coil ect. off of another engine with solid state coil and so forth or do i need to have that new armature, i have several solid state parts and engines that is more of the ? thanks for the response
