craftsman transaxle #150073
milkman22's Avatar
KY
04-03-09, 01:48 PM   #1
i have an 18.5 hp craftsman l&g tractor with a hydro-gear transaxle-model #150073. forward movement got slower & slower until it was almost non-existent. changed filter & fluid. now forward movement is non-existent. reverse seems to be fine. makes no unusual noises. took to some guys that "work on mowers" & they have had it apart 2 times. they can find nothing and it still has no forward & reverse seems to be ok. any ideas. thanks. p.s. has excellent kohler engine but a new transaxle is $800-$1300 and i just need it to mow around my shop occasionally.
geogrubb's Avatar
MO
04-03-09, 04:37 PM   #2
It sounds like the same problem that Craftsman with Peerless have. There is nothing wrong with the transaxle or the pump. The sleeve between the pump and the transaxle(the one controled by the lever to be able to roll it) gets ground out and will not function, it's a $12 part. I will try to insert an image. Have a good one. Geo
The first link shows the good side of the sleeve
http://i190.photobucket.com/albums/z...cture002-1.jpg
The second is the side that has been destroyed, maybe because of the sealer.
http://i190.photobucket.com/albums/z...Picture003.jpg
milkman22's Avatar
KY
04-03-09, 05:23 PM   #3
already been checked
thanks! they said they have checked this collar & also the input shaft & pulley. any other ideas?
geogrubb's Avatar
MO
04-03-09, 07:13 PM   #4
It is the only part in the system that will make them act that way(disclaimer: I know nothing about nothing). If you don't want to do it yourself get a neighborhood kid/mechanic wanna be to take it apart and find out. You have nothing to loose and a lot to gain($800-1300-$12). Have a good one. Geo
milkman22's Avatar
KY
04-03-09, 07:19 PM   #5
thanks. may have to haul it home and ck. it myself! "if you want it done right do it yourself." thanks again!!!
Airman's Avatar
TN
04-04-09, 06:41 AM   #6
I have not worked or trained on this particular transaxle and pump but they are all similar. These transaxles look worse than they are. I do not have the service manual for this one but I will see if I can get it from my distributor on Monday. Try to isolate the problem with your transaxle to the BDU-10L-122 pump or the drive assembly. Possibly the pump is not working or a shaft the pump drives has teeth stripped. I hope that the folks who took it apart put it back correctly.
Send me a PM with an email address and I will send you the manual if I can get it.
Look at this manual it gives basic troubleshooting information. Although, this does not cover the exact transaxle many things are the same.
http://www.gardening-tools-direct.co...5321635-78.pdf
http://www.m-and-d.com/pdfs/hydrogea...10L_150073.pdf
http://www.oscar-wilson.com/manuals/...AR/BDU-10L.PDF
milkman22's Avatar
KY
04-04-09, 05:56 PM   #7
that would be great. reverse is still working so i would think the pump is still moving fluid. to change directions of travel does the pump change directions or is the flow of fluid re-directed after it comes out of the pump? e-mail is [email protected] thanks again. tim
geogrubb's Avatar
MO
04-04-09, 07:11 PM   #8
Please post the results. Have a good one. Geo
milkman22's Avatar
KY
04-07-09, 03:56 PM   #9
can any of you answer this question? reverse is still working on this transaxle so i would think the pump is still moving fluid. to change directions of travel does the pump change direction of rotation or is the flow of fluid re-directed after it comes out of the pump?
Airman's Avatar
TN
04-07-09, 05:45 PM   #10
The pump turns in the same direction at all times. Reversing pump swash plate angle, which then in returns reverses the flow of oil being pumped to the motor, reverses direction of motor rotation.
milkman22's Avatar
KY
04-08-09, 03:55 PM   #11
thanks. sounds like my pump should not be the problem! at least this elemenates one thing.
