neutral- to- ground load or bond in generator.
Old 04-08-09, 02:02 PM
Question neutral- to- ground load or bond in generator.
HOW do I remove so I can connect my automatic transfer switch ? A P C model uts6 transfer switch . model no. 04791 generac 3.4 k.w. centurion 3500 generator, (3400 watts )
Old 04-08-09, 05:23 PM
A portable generator, even when equipped with electric start, will not work with an automatic switch. You can use a manual transfer switch but as you have discovered, the generator's GFCI causes problems. Disabling it is not recommended.
Old 04-09-09, 05:28 AM
generator neutral- ground bond.
Thanks for your reply Canuck Roy. generator is a permanent stand by generator with it's own in house remote start transfer switch with 2 duplex receptacles.gfi type. connecting these to the UTS-6 trips the gfi's because of the bond issue. manufacture said it needed to be open.
Old 04-09-09, 06:54 AM
O.K. I assumed it is a portable because of the output, standbys are usually much larger.
