5hp briggs wont idle
Old 04-17-09, 09:50 PM
H
I have a 5hp briggs and it will not idle I messed with the card needles and nothing. and its not the idle screw
Old 04-17-09, 09:52 PM
cheese's Avatar
Received 45 Votes on 40 Posts
What engine do you have? Got #s?
Old 04-17-09, 10:08 PM
H
i got the numbers modle 82502 type 0150 01 code 6504121
Old 04-18-09, 03:22 PM
D
first remove and clean carb and better yet rebuild it
Old 04-18-09, 08:43 PM
cheese's Avatar
I agree, rebuild the carb with new gaskets and if this has a diaphragm (I don't recall what carb these had). I believe it has the tank-mounted auto-choke pulsa-jet?
Old 04-18-09, 09:13 PM
H
i got a carb rebuild and no difference
Old 04-18-09, 09:56 PM
cheese's Avatar
Did you clean the carb and verify that every internal passage is clear?
Old 04-18-09, 10:46 PM
H
yea i made sure there all clear
Old 04-18-09, 10:56 PM
cheese's Avatar
Could be an air leak. Check where the carb mounts, and where the intake mounts. Make sure there are no leaks there. Also, make sure the points are set properly, flywheel key is in good shape, and the engine has sufficient compression. If all checks out, there is still a carb problem.
