MTD transmission help
Old 04-19-09, 11:05 AM
I have a 2001 MTD (yard machine) with the auto. transmission. My problem is.... I try to put into forward gear, the mower will not move and act like it is locked up and belt will start to get real hot (burning up). If I go into neutral, it will act like it is in reverse and move fine in reverse direction. and When I put it into reverse it will run perfectly fine also in reverse direction. Is there a semi-quick fix to this or is the transmission junk??
I did buy this thing used, so I do not have any previous history on work done on unit.
Old 04-19-09, 01:32 PM
31YTech's Avatar
Does the machine push easy in neutral ?
Old 04-19-09, 01:52 PM
It will push easy backwards when in neutral, but trying to push it forward, the tires are not turning.
