Mtd gas edger not working
Old 04-19-09, 02:17 PM
Hi all,
This morning I bought a used MDT gas edger (Model Series 580). The engine was cold and the guy started it up on the first pull and it ran like a champ. I had to lay the edger down to transport it home. However, when I got home the engine wouldn't start. I took the spark plug off and discoverd it was covered in gas. I then took the air filter off and found gas in the basin where the air filter sits. The air filter itself was not wet. Is it possible that when I laid the engine down that gas somehow spilled into somewhere it wasn't suppose to go? At this point I only replaced the spark plug with negative results. The engine is a B&S model series 90000. Should I just wait a few days to let everything dry out? Any suggestions would be apperciated. Thanks!
Old 04-19-09, 06:50 PM
cheese's Avatar
It should be ok after it dries out. You can help clear the gas by cranking it over without the plug in it. Make sure there is no gas in the oil.
