mower tach
Old 04-22-09, 02:23 PM
wwc
wwc is offline
mower tach
How can i hook up a tach to my mower to check rpm's
it's a standard briggs engine.
Old 04-22-09, 02:35 PM
Upvotes Received: 16
Yamaha has a tachometer that has a pickup lead that simply wraps around the spark plug lead a few times. They are about $35 to $40 as I recall.
Here's a link, although not Yamaha, of the same thing. Tiny-Tach: Gasoline Tachometers
Old 04-22-09, 02:37 PM
Is this on a lawn tractor, push mower, riding mower? Do you want a permament mount or just want to read the RPMs on different equipment?
Old 04-22-09, 04:15 PM
hopkinsr2's Avatar
When I got my D.V.O.M, I made sure it had a tach function in it. This way, one meter works for volts, amps, ohms, hertz, & even microfrad (if I ever need it for condensers,,) & a bunch of other stuff I'll probably never use..Quick & easy to use,,, Roger
Old 04-22-09, 06:28 PM
wwc
wwc is offline
thanks for the replys, i was thinking only of a diagnostic reason but maybe a permanent hook up if it was cheap enough.
it's for a riding mower but i wanted to use it for any mower, but didn't know where to attach a lead or wire,
Old 04-22-09, 07:36 PM
Upvotes Received: 1
You can get a TREYSIT Sirometer, made in Germany, Tecumseh Part #670156 which will handle from 800 to 50,000 rpm or 14 to 750 cycles for $10-$15. You just hold it on the engine and it will tell you the rpm. I have used one for a long time, it is accurate to within 100 rpm. I just checked Oscar Wilson Lawn Mower Parts Missouri they have it for $11.11. Have a good one. Geo
Old 04-23-09, 03:30 PM
I just installed a SunDec tach/hourmeter on my new Poulan.
I love it. Works great. Easy installation. Price is right.
Hour Meter with Tachometer | Hour Meters + Gauges | Northern Tool + Equipment
Old 04-23-09, 03:39 PM
wwc
wwc is offline
thanks for the help i appreciate it
