honda eb11000 runs and stalls runs and stalls
Old 04-25-09, 02:46 PM
Y
i have a honda eb11000 and it will run for 15 in from cold then shut down it can start right up again run for 10 min then shut down and so on and on
i have ran it with the gas cap off-same thing
i have put a spark tester to it and spark stops when it shuts down i just dont know what is telling it to stop or why it stops sparking
engine serial is gcad-1094738
20 hp 615cc v-twin
i have been pounding my head on the desk tying to figure it out im not sure what to do next
any help is appreciated
thanks
Steve
Old 04-25-09, 03:00 PM
Received 5 Votes on 5 Posts
What does your engine drive?
Old 04-25-09, 03:40 PM
Y
it drives a generator
its about 6 years old and only 50 hours on it
Old 04-25-09, 04:10 PM
Typically a component like an ignition coil causing problems wouldn't start right back up without having time to cool so I wouldn't put that at the top of the list.
It could be a low oil sensor acting up. I'm sure you have checked the oil level.
What you could do is go to the ignition coil and disconnect the kill wire coming from it and see if it keeps running. That eliminates all the engine controls from the equation, like safety devices, ignition switch, etc. With an ignition module (electronic ignition without the battery) the engine shutdown works by grounding the module/coil.
Let me see if I can come with a parts diagram for that thing.
Old 04-25-09, 04:16 PM
Do you know what the engine on that is = the model ID? Looking at a parts diagram, with the twin it has engine stop diode and a pair of coils.
OK, it must be a GX 620
Old 04-25-09, 04:23 PM
Y
engine serial is gcad-1094738 is that the number you are looking for?
Old 04-25-09, 04:26 PM
No, hold on, the GX 620 model is the one.
Old 04-25-09, 04:30 PM
Y
so i should unplug the stop diode? and see if it still stalls ?
Old 04-25-09, 04:54 PM
You could disconnect the engine stop diode (for the twin coils) and if it kept running, it would isolate the problem somewhat.
This diagram, under ignition - the number seven is the diode. Or you could disconnect the coils(1 & 3) individually before the kill wire gets to the diode.
http://webservices.motorsportdealers...J10E/2000B.Gif
You also have the oil lubrication switches (low oil level) and /or the low pressure (if pressure fed and oil filter) that would serve to stop the ignition. I have a feeling that may be where you have the problem, but no way to know for sure. I imagine your coils are fine.
Keep in mind if the problem is in the oil pressure/level or has to do with the lubrication and the sensors for that fault are accurate, you would certainly want to to fix the fault before running the engine.
Old 04-25-09, 05:12 PM
Y
right that will isolate it to being ignition then its a matter of which sensor or switch is grounding to kill it right ?
Old 04-25-09, 05:36 PM
Yep, and it's really just a good place to start. If the coils or kill diode were at fault, it would be conclusive on what to replace. If it's not in those parts the other direction would hold a number of other possibilities. I don't know what kind of shutoffs (if any) that generator would put on the engine.
