Kohler engine won't start without priming
Old 05-01-09, 09:10 AM
Hi,
I am working on a Kohler twin cylinder 20hp magnum engine. Model number is M20QS. It runs great, once I prime it by putting a little gas in the carburetor. After I start it by priming, I can shut it off and it will restart everytime without priming as long as I don't let it sit too long. Is this a fuel supply line/filter problem or is it more to do with the fuel pump? Once started, the engine runs smooth at high and low speeds.
Thank you
Old 05-01-09, 09:31 PM
hopkinsr2's Avatar
Check the throttle / choke cable to make sure the choke is fully closed when choked.. It may just be an adjustment of the cable... Roger
Old 07-24-14, 06:15 PM
same problem
I have the same problem with my kohler 18 hp courage. I simply cannot figure it out. Pray someone knows what causes this.
Trackbacks are On
Pingbacks are On
Refbacks are On
