B&S Carburetor Solenoid problem
Old 05-01-09, 12:07 PM
I have a Bolens MTD 15.5 Lawn Tractor
Engine code 283H07 0197E1 030915ZE
The solenoid on the carburetor won't disengage and allow gas into the carb.
I have taken the solenoid off and checked it, it is clean and clear of debris, and will work when worked manually.
Also, tested it by connecting 2 wires to the mower battery and touching the contacts, the solenoid will function this way.
When connected to the terminal from the mower the solenoid will not work when switching the engine on.
Checked the voltage on the terminal with switch on and I am reading the same as on the battery, although the voltage is gradually going down a .01 volt at a time, as long as the switch is on.
The mower does turnover and will run when gas is poured in the air intake.
Thanks for any help in advance.
Great site by the way, I have a feeling I will be comming here a lot !!!
Old 05-01-09, 03:42 PM
Received 3 Votes on 3 Posts
You could just have a bad wire/wires leading to the solenoid. You could run a test wire out of the ignition switch and run the problem down that way.
If you get it to open, but it gradually closes, the solenoid itself could be bad.
Old 05-01-09, 08:20 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Does the ground wire at the solenoid have continuity to ground? Check voltage at the solenoid wire with the solenoid connected and see what it reads as well. If it works when you connect it to a battery, it is a good solenoid.
Old 05-04-09, 01:52 PM
I have a temporary fix in place, and was able to get the mower running, and was able to cut the grass, which made my wife very happy, she had mentioned something about the neighbors starting to talk !!!
I will try the suggestions below to see if I can get the solenoid to work, or decide that it is bad except when hooked directly to the battery.
I had already thought of just running a hot wire to from the battery to see if it would work when it is connected to the carb, but haven't done that yet either.
I found a place on line, that has the solenoid for $38, does this sound reasonable?
Old 05-04-09, 05:21 PM
You could verify the problem as the solenoid by using a like threaded and length bolt, borrow the gasket from the solenoid and install the bolt in place of the solenoid.
Be certain to tape/tie/restrain the wire to the solenoid so it can not come into contact with a grounding surface.
Old 05-04-09, 07:45 PM
cheese's Avatar
...or just clip the needle off the solenoid to render it ineffective.
Old 05-06-09, 08:25 PM
where did you find a solenoid for 38 dollars and would it work on a 14hp kholer engine. thanks
Old 05-08-09, 12:54 PM
Thats what I did, to get the mower to work.
Old 05-08-09, 12:58 PM
Thought about doing that also.
Old 05-08-09, 01:03 PM
I didn't, I found one for a 15.5 Briggs & Stratton engine.
