No electrical power in John Deere L110 Auto
Old 05-02-09, 03:19 PM
I used my mower, and I needed to service it. This was my first time changing the spark plug...
I changed the battery, the oil, and the spark plug. Now, I have no power to the lcd screen (or the rest of the mower...). The battery is new and good.
Could I have not tightened the spark plug in tight enough? Could I need to put the rubber connector onto the other end of the spark plug tighter?
Any suggestions would be welcome...
Old 05-02-09, 04:14 PM
Received 33 Upvotes on 32 Posts
Spark plug is not the problem, but it needs to be in snug.
Probably the battery. Double check the way you hooked up the cables.
Old 05-02-09, 07:36 PM
cheese's Avatar
Received 133 Upvotes on 122 Posts
Make sure the battery cable connections are tight, and the battery is not connected backwards.
