craftsman LT 1000 wiring
Old 05-09-09, 11:37 AM
Post craftsman LT 1000 wiring
Ineed a color diagram, photo or description of the #16 connector switch on the right side of the Kohler 17.5 hp engine.
My hood fell on it and detached all the wires. Can anyone help.
Thanks
Bob
Old 05-09-09, 10:44 PM
cheese's Avatar
Received 17 Votes on 15 Posts
What model mower? A connector with 16 wires? Switch?
Old 05-10-09, 07:52 AM
craftsman Lt 1000
Thanks for answering so quickly.
The wiring problem is in a connector on the right side of the engine. It has 6 pins on each side and it has 7 wires going in and the other side of the connector has 7 wires coming out. unfortunatel:wally the wires coming in and the wires going out are different colors so I can't match them up.
It it helps I can send a photo. The model # is 917272070
Thanks again,
Bob
Old 05-11-09, 11:28 PM
cheese's Avatar
I'll see what I can find. Post a pic as well if you like.
Old 05-12-09, 05:35 AM
Take a look at the electrical section in the manual linked below. This may answer your question.
http://www.gardening-tools-direct.co...000_173750.pdf
Old 05-13-09, 12:18 AM
cheese's Avatar
I looked at one similar to yours today. On the multi-connector, I had these colored wires connected this way. Look at your wires, and if all colors match, I'd say it would be safe to assume you can connect as follows:
Orange wire on the mower harness going to yellow on engine,
Blue on harness to red on engine,
Red on harness to black on engine,
Black on harness to white on engine,
And on a separate connector but in the same group of wires was a yellow wire coming from the harness going to a green wire on the engine.
Hope that helps!
