Craftsman riding mower dies every 5 minutes / fuel leak
Old 05-12-09, 11:29 PM
Hello friends-
Mower part # 917.271552
Sears craftsman 15.5 OHV - Old but reliable until this year.
Main problem - Mower runs fine for approximately 10 minutes when first fired up. It sputters and dies quickly after 10 minutes. Let it sit for 2 minutes and it will run like a champ for another 5 minutes. Dies again - This goes on until I give up. After searching similar problems, I have replaced:
1. Ignition coil
2. Solenoid/armature
3. New air filter
4. New Oil Filter/changed oil
5. New fuel filter
6. new gas cap/vent
7. Cleaned all fins
Have NOT replaced the fuel solenoid.
Nothing works - on a positive note, the mower will start back up quicker than it did before - had to leave it be for 5 minutes
in the past before it would start back up and run well for me...now I can let it sit a minute or two and then get another 2 minutes out of it.
That is problem #1.
Tonight, I decided to open up the carb bowl/float and check for any gum formation in the pin/ports. Nothing there. Cleaned the carb, reassembled and put her back together. Hooked the gas line back up to the arm and after 10 minutes, I heard a pitter patter of gas dropping down the underside of the muffler. No fuel can be seen leaking from the carb cup/solenoid. The fuel is coming out the vent on the bottom of the muffler at appx 2 drops/second.
I can live with the dying engine, but I have created a whole new problem opening up the carb cup and now have a gas leak issue.
Any help would be appreciated.
link to manual:
http://www.managemyhome.com/mmh/lis_...M/L0203157.pdf
Old 05-13-09, 12:00 AM
cheese's Avatar
Received 17 Votes on 15 Posts
The fuel leak is due to a bad, missing, or improperly seating needle valve in the carb. Open it back up and take the needle out...clean it and the seat with a Q-tip, and see if it quits leaking. You probably have gas in the oil now too, so don't run it without changing the oil if so.
As for the other problem, I suspect a fuel line that has collapsed internally. Replace the fuel lines, blow out the inlet where the fuel line connects to the carb, and fix the leak in the carb. I think that will fix 'er up.
