Kohler cv14s engine
Old 05-14-09, 12:00 PM
Kohler cv14s engine
I have a model number 917.255460 tractor with a Kohler
CV14S type number PS 1452 engine.
The tractor started to act up two weeks ago. It starts great. After about ten minutes of runnibg, the engine shuts down. No bogging or sputtering, just stops.
I have replaced the plug, drainned and added fresh fuel, replaced the gas filter to no avail.
After speaking with several folks I was told that the problem is the coil.
How do I replace the coil?
Thank you
Old 05-14-09, 08:40 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Might be the coil, might not. What does it do when you try to start it? Have you checked for spark? I can tell you how to change the coil if you want, but I'm not into changing parts without knowing if they are bad or not...know what I mean?
Old 05-15-09, 06:58 AM
CV14S Kohler
The engine starts fine. Idles fine. When the engine gets hot, it just stops. It does not bogg or sputter at all. I then have to wait appx. 1 hour for the engine to start again.
I have replaced the plug and fuel filter and put new fuel into the tank.
Thanks
Old 05-15-09, 07:22 AM
BFHFixit's Avatar
You will need to remove the engine shroud and possibly other components to access the coil. The coil is where the high tension lead (spark plug wire) originates.
This link http://www.kohlerengines.com/onlinec.../tp_2339_d.pdf is to a service manual that should cover your engine.
Section 8 has detailed instructions on how to test the coil.
Old 05-15-09, 12:17 PM
Thank you,
I will let you know how it works.
Thanks again
Old 05-15-09, 10:23 PM
cheese's Avatar
Your description does sound like classic coil failure. Still, I would check for spark when it dies just to be sure.
