B&S 28N707 crankcase repair
Old 05-15-09, 03:45 PM
I am working on a B&S 28N707. It was backfiring when attempting to start it. It also had to much compresion when starting. It had a sheared flywheel key which I replaced and I adjusted the valves.
This got it running but there is a small hole in the top of the crack case so it is leaking oil. It looks like the hole may have been caused at some time by a bolt being inserted to far when using a puller to remove the flywheel.
I am looking for any suggestions on how I might repair this hole. I was thinking I might be able to drill it out and tap threads to instal some type of plug but I am not sure it is thick enough to get threads in.
Any ideas?
Thanks
Old 05-15-09, 10:06 PM
cheese's Avatar
I'd say clean it well and JBweld a small patch of metal over it.
Old 05-15-09, 10:10 PM
hopkinsr2's Avatar
Clean it up really good with carb cleaner & put something like J.B. weld on it & let it cure a couple of days?? There's no oil pressure in that area, is there?? Roger
Old 05-17-09, 04:38 PM
The J.B. Weld work great.
Thanks
Old 05-17-09, 10:39 PM
cheese's Avatar
Great! Glad we could help and thanks for the update!
