storing my gas powered snow blower
gianni's Avatar
NJ
05-16-09, 11:11 AM   #1
hey all,
I need to store my gas powered snow blower for the summer. should i just fill it and add fuel stabilizer? What's the best way?
Thanks!
goldstar's Avatar
OH
05-16-09, 11:26 AM   #2
If you fill it and add stabilizer, run it long enough to insure that the mix is in the carb.
Personally, I always use stabilizer, run out the remaining fuel in the spring, drain the carb bowl - mine has a spring loaded drain button on the carb. I then pull and clean the plug, put a shot of oil in the cylinder, replace the plug, pull the starter just enough to get into the compression stroke, and store it. It's now 12 years old and still starts on the first or second pull each winter.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
Concretemasonry's Avatar
MN
05-16-09, 01:29 PM   #3
If you use it where the snow, slop and slush may contain salt, wash it down to minimize and corrosion.
indypower1's Avatar
NH
05-17-09, 06:50 AM   #4
Add Stabil and dry gas (isopropel) to the gas. My snowblower has a gas shut-off. Then I start it and let it run on fast for about 5 mintes, then idle it down for about 5 minutes. This way the Stabil gets into all internal "circuts" of the carb. The I shut-off the gas, crank it up to fast and let it run out of gas.
Then I take the gas hose off the shut-off, put a longer hose on it, stick it in my gas can and open the shut-off and drain the snowblower gas tank. Now I have gas to use in my lawnmower.
