MTD Yard Machine Transaxle Repair
DRandy's Avatar
05-21-09, 10:54 AM   #1
MTD Yard Machine Transaxle Repair - Need Help
I have a MTD Yard Machine that has grinding noise in the rear underneath the seat. I took it apart and didn't find any problems with the pulleys, belts, etc.
Then I went deeper, took off the tires and the transaxle. I found 3 holes in the transaxle and took it in to my local mower shop. They said I needed to get a new one. Their quote was $444. (Replacement part number is #918-0551A.) So I looked around on the web and the lowest price I could find is $340.
I found a post in this section (can't find it now) related to repairing this after searching Google. A moderator of the post suggested getting a pdf download from mymowerparts.com. So I did that and read through it. It references a service kit #753-0714 for transmission housing replacement. But going to the web site, there is no kit available.
I have a few questions:
1. Does anyone know where I can get replacement parts for this transaxle's troubled areas (differential, gears, shift fork, etc.)?
2. Can the holes in the housing be arc welded shut or epoxy glued shut?
3. Has anyone done this type of repair?
Thanks for your advice.
31YTech's Avatar
FL
05-21-09, 07:06 PM   #2
Randy,
You can check with these places for replacement parts;
MowPart.com - Home
Lawn Mower Parts
Welcome to Newark Mower Center
First Quality Sales - Bolens,Briggs & Stratton,Briggs & Stratton Power Prod
Honest Engine Equipment - Home
I've never repaired a hole in a case but you can check with your local welding shop, Depending on where the hole is they may be able to heliarc it.
EDIT; I just found the housing kit here, MTD OEM Parts Search Results!
Ref # Part # Description Context Note Foot Note
[View supersession data for this part]
1
716-0231
Add to pick list
E-ring, .75
2
721-0338
Add to pick list
Seal, .75 x 1.0 x .125
3
711-1431
Add to pick list
Drive Shaft
4
741-0340
Add to pick list
Sleeve Bearing, .75 x .1.0 x 1.0
5
736-0495
Add to pick list
Thrust Washer, 1.0 x .632 x .0
6
717-1362
Add to pick list
42-tooth Bevel Gear
7
717-1363
Add to pick list
42-tooth Bevel Gear
8
750-1234
Add to pick list
Spacer, .633 x 1.0 x .513
9
718-0228
Add to pick list
Clutch Collar
10
741-0335
Add to pick list
Needle Bearing, .625 x .813 x .495
11
719-0394
Add to pick list
Lower Housing
12
736-0336
Add to pick list
Flat Washer, 5/8 x 1.0 x .030
Use applicable flat washer in this application allowing proper end-play.
736-0337
Add to pick list
Flat Washer, 5/8 x 1.0 x .040
736-0349
Add to pick list
Flat Washer, 5/8 x 1.0 x .020
13
736-0519
Add to pick list
Flat Washer, .70 x 1.125 x .031
14
741-0336
Add to pick list
Flange Bearing, 5/8 x 3/4 x 3/4
15
741-0337
Add to pick list
Flange Bearing, 5/8 x 3/4 x 15/16
16
750-1238
Add to pick list
Spacer, .635 x 1.0 x .27
17
611-0133
Add to pick list
Detent Shaft Assembly
18
618-0424
Add to pick list
Differential Assembly
19
661-0006
Add to pick list
Brake Assembly
[View prior data for this part]
20
710-1325
Add to pick list
Self-tapping Screw, 1/4-20 x 1.625
21
710-1206
Add to pick list
Self-tapping Screw, 1/4-20 x 2.375
22
717-0678
Add to pick list
Brake Pad
23
732-0863
Add to pick list
Compression Spring
24
741-0862
Add to pick list
Detent Ball
25
761-0202
Add to pick list
Brake Disc
26
711-1430
Add to pick list
Input Shaft
27
716-0108
Add to pick list
Retaining Ring, .437
28
717-1464
Add to pick list
14-tooth Bevel Pinion
29
719-0580
Add to pick list
Upper Housing
30
736-0335
Add to pick list
Thrust Washer, .635 x 1.25 x .042
Good Luck
DRandy's Avatar
05-22-09, 05:23 AM   #3
Thank you.
I'll look into it.
