No start chainsaw
jdono's Avatar
05-21-09, 01:19 PM   #1
No start chainsaw
My sons 028 woodboss won't start, replaced carb kit, cleaned carb with air, set lever on needle, a few thousands below flush, it won't run log enough to adjust carb, spits some gas out carb, tried changing adjustments hi and low. Checked connection tube from carb to cylinder, seems to be ok, spark arrestor and muffler ok. I used to fix these for a living but I am stumped!
Knock on wood's Avatar
05-21-09, 11:16 PM   #2
Sounds like a leaking crank shaft seal might be the culprit.
cheese's Avatar
GA
05-22-09, 12:02 AM   #3
I guess it has plenty of compression? Is it flooding?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
jdono's Avatar
05-22-09, 02:24 AM   #4
It seems like it isn't getting gas as it needs to keep running, sometimes choking a little will help to stay running
cheese's Avatar
GA
05-22-09, 06:46 PM   #5
How about the compression? Take a look at the piston and see if it has scratches on it.
God bless!
geogrubb's Avatar
MO
05-22-09, 07:20 PM   #6
When you installed the carb kit, if you installed the new metering arm, put the old one back in unless it was very worn as it has the proper height setting. Have a good one. Geo
