Help with Honda HRS21 Mower
jl66redcpe's Avatar
NJ
05-22-09, 09:58 AM   #1
The gas shut off valve on this mower has a slow leak. The shut off valve is attached to the carb. It appears that it can be removed however I do not have a tool to remove the two screws. Does anyone know what kind of heads are on the screws that hold the shut off valve to the carb and if in fact it can be removed. -- thanks
puey61's Avatar
NY
05-22-09, 10:01 AM   #2
Torx. Should be able to find a set at any Sears.
donaldp's Avatar
05-23-09, 01:54 PM   #3
If it leaks as in doesn't turn all the way off and you can't remove it, an option is to add another one in the gas line. I did that on a troybilt.
jl66redcpe's Avatar
NJ
05-24-09, 03:26 AM   #4
Thanks for the reponses.
Puey - I thought it was Torx also however none seemed to fit.
Donalp - it seeps when it the valve is on and fuel is flowing.
