Craftsman Mini-Tiller carb???
Old 05-22-09, 12:52 PM
Craftsman Mini-Tiller idle issues
Hi All,
I have 2 cycle Craftsman Mini Tiller 316.292561.
It turns on fine when the EZ is push, but when I increase throttle the EZ switch kicks back and I loose power without any load at all. (Like it is choking)
I cleaned air filter and checked gas lines, all is fine.
Also and noticed that when I put my thumb on the air entry hole on the carburetor to block some of the air it work great.
I have not noticed any screws for air/gas mix adjustment on the carburetor.
Any ideas on how to approach this issue.
Thanks.
Old 05-22-09, 06:29 PM
cheese's Avatar
Sounds like you need to clean the carburetor.
Old 05-22-09, 06:34 PM
hopkinsr2's Avatar
I'm thinking that if you pull the carb apart & clean all the passages with compressed air,,,Install a carb kit & adjust it,,,
You should be fine
Roger
