scag zero turm mower with Kawaski 19hp battery drain
Old 05-23-09, 02:41 PM
I have a scag tiger cub with the Kawasaki 19hp. the battery is not recharging. I have replaced battery new one still drains.
Whre is the charging coil and is it easy enough to change?
thanks
Bucky
Old 05-23-09, 04:35 PM
hopkinsr2's Avatar
What is the battery voltage when the engine is running?? Also how long does it take to discharge the battery & does it still discharge with the battery disconnected??? Check for a draw while diconnecting stuff ( like key switch,, Voltage regulator ,,,Etc & let us know if you see anything..Maybe post some engine #'s as there may be differances in the charging systems & they may help the pros... Just some thoughts... Roger
Old 06-01-09, 08:56 AM
Scag Tiger Cub 19 hp Kawasaki
Roger
Thanks for your reply. I did replace the voltage regulator. Did not help.
The mower runs for 2 hrs before the battery drains after a overnight 2 amp charge.
I will get a meter and check the readings as you suggested. Also I will look for shorts in the wire harness.
Thanks again.
Bucky
PS. Is the charging coil/stator hard to replace?
The engine# FH601V-AS29
Old 06-01-09, 07:33 PM
Roger
The voltage with the mower off is 12.64 . With the mower running the voltage is down to 12.25. I did change out the charging coil. Battery still draining and the voltage did not increase while engine running.
Ideas?
Thanks
Old 06-01-09, 10:00 PM
hopkinsr2's Avatar
If you replaced the regulator & the charge coil (It's under the flywheel.. Right??) I think that's all there is to the charging system... Have you verified that all the connections & fuses are O.K... The charging coil that you replaced,, What did it look like & where did the wires go?? Just to make sure it wasn't a coil you changed,,, Sorry,, Roger
Old 06-02-09, 12:48 PM
Roger
Yes, I changed the charging coil under the flywheel. The wires went to the voltage regulator. No Problem.
I will check all the fuses and connections tonight.
Thanks
Old 06-03-09, 07:02 AM
Scag Tiger Cub 19hp Kawaski charging problem
Roger
Guess What?
It was the fuse. You were the only person to tell me to check them. Thanks
Voltage across the battery is up when the engine is running.
Should be good to go.
Bucky
Old 06-03-09, 08:39 PM
hopkinsr2's Avatar
Hey,,I'm glad to help & great to hear all is O.K. Thanks,, Roger
