Stihl FS 55 trim head too tight.
Old 05-24-09, 03:09 PM
Well, I have done it now. I removed the cutting blade to put the string head on my Stihl FS 55, and when I installed the string head unit, I forgot to put on the metal collar first. That is the collar that allows the head to spin freely. You guessed it, when I started the trimmer, the head tightened up and now I cannot get it back off. It is tight, but I am able to turn it by hand; the problem is the screw turns with it so it will not turn off. Since the metal collar is not on it, I cannot stick a screwdriver through the hole to lock it.
Any suggestions? Is there any way to lock the shaft from turning other than the hole down at the head?
Any advice would be appreciated.
Joe
Old 05-24-09, 07:33 PM
cheese's Avatar
You may have to remove the boom and hold the shaft from turning at the other end.
Old 05-24-09, 08:22 PM
You are not the first to have done that. Don't ask how I know.
Old 05-24-09, 08:59 PM
Thanks. How do I remove the boom so I can keep the shaft from turning at the other end?
