Won't run without choke
Old 05-24-09, 05:35 PM
just bought a used suzuki 700 gas generator for camping Only prob is it won't stay running unless choke is on 1/2 to full, Turn choke off and generator quits Starts with 1-2 pulls Should have checked it better when I bought but was in a hurry
Old 05-24-09, 07:13 PM
cheese's Avatar
It just needs the carburetor cleaned. Get some carb cleaner, take it off, open it up, and clean it out. Make sure all passages are clear.
Old 05-25-09, 06:07 AM
indypower1's Avatar
Yes carb needs to be cleaned. Since it does run, I would try SeaFoam in the gas first. Can be found at any auto parts store. This is quicker & easier than removing the carb. It's worth a try. You will need to run it for at least 15 mins then slowly & gradually turn off the choke.
Old 05-25-09, 09:56 AM
thxs for the help I took carb apart and cleaned works fine now Any one know what idle should be set at
