mantis tiller 2 cycle
i cant get a spark on the tiller I have changed the plugs but still no spark:
Make sure the plug is grounded well to the metal of the engine. I sometimes use a jumper wire as a lot of the plastic shrouds keep the plug from sitting on a good ground.... Wiggle the kill switch around incase it's kinda stuck in the off position... Lastly, remove the kill wire from the coil & try it.... If you don't have any spark with the kill wire off the coil,,, I'm afraid you'll need a coil.... Roger
