Electric Clutch removal
Old 06-02-09, 06:17 PM
Received 4 Votes on 4 Posts
I wrote in about a year ago about removing an electric clutch mounted to the engine on a 1989 Toro HMR 1600 rotary mower. I can change the destroyed belt without removing the clutch, but it would be a LOT easier if I could drop the clutch out of the way. You are not supposed to use a puller on it, but this definitely needs some outside force to remove it. Was there a special tool for this job?
Old 06-03-09, 01:12 AM
cheese's Avatar
Received 17 Votes on 15 Posts
It's supposed to just slide off when you remove the center bolt. If it doesn't, you'll have to work with it to persuade it however necessary. I don't recommend using a puller though. Try prying it down from both sides at the same time with a couple boards.
Old 06-03-09, 04:59 AM
Everything is so flimsy outside the actual sleeve that is stuck on the crankshaft, it just bends when I apply pressure on it with anything. Im soaking it with penetrating oil from the top side but I have to be careful with that too. I will let you know what finally works.
Thanks for the reply!
