How to install Oil Separator in Kohler 27 HP
hi all... new member here... first post.
I just installed a NEW Kohler 27HP motor in a used Craftsman GT3000 garden tractor. In the process of hooking everything up I pulled the (plastic tube) oil separator out of the #1 head cover so I could get at the throttle/choke connections. Now trying to reinstall it I have problems.
The bottom of the separator (tube/can) has a rubber tube-like protrusion that goes into a hole in the top of the cover. Thing is I cannot twist/turn/push it back in! It simply compresses and squishes out on me. I'm afraid to pry it in with a screwdriver for fear of puncturing the rubber.
Can anyone tell me the proper way to reinstall this?
Thanks in advance for any assistance!!
k1hop in CT
k1hop in CT
dcole4757
voted this post useful.
k1hop,
Remove the rubber bushing from the breather separator, Insert it into the hole in the valve cover. Put a light film of oil on the breather separator with your finger then push it into the bushing.
Good Luck
Good Luck
