John Deere front mower f915/f935 problem
Old 06-04-09, 09:58 PM
C
As I finished mowing today I noticed the blade was disengaged and would not hold engaged by itself. If I held the handle it would mow, but as soon as I let go it would disengage. Would do I look for? Thanks
Old 06-04-09, 10:04 PM
cheese's Avatar
Received 94 Votes on 87 Posts
Does this have a knob you pull to turn the blades on? If so, it is bad (pto switch). If this has a hydraulic valve you turn on via a lever, reply and let us know.
Old 06-05-09, 05:26 AM
C
It has a pto lever. It mowed fine till I was done. Lucky for that moment anyway.
Old 06-05-09, 11:25 PM
cheese's Avatar
I believe there will be a spring that connects to the lever, and pulls down to another connection point. This spring probably came off. Have a look in that general area.
Old 06-06-10, 11:40 AM
I know this is an old post but maybe my answer will help someone else with the same problem.
I had the same problem with mine, it turned out to be the parking brake safety switch, when the parking brake is on the electro magnet that holds the pto on doesn't get power and the pto won't stay enabled.
If you have a voltmeter you can pull the connector off the electro magnet and test it for voltage. with the key turned on and the seat safety switch activated or bypassed you should see 12v to that connector, if you don't try playing with the parking and emergency brake to see if you see voltage.
I bought mine used and knew nothing about it, the instruction sticker on the floor is worn and you can't read it to well so i didn't know that the parking brake was on (the brakes are in need of adjustment so i didn't even notice). My pto worked fine the first couple times i used it and then did the same thing as yours. Troubleshooting the electrical system with a voltmeter is how i figured out that my parking brake had been on the whole time.
In case your not sure the parking brake is the little black knob on the steering post, it should be up an to the left sitting in the little notch.
