Craftsman Ride On Bad Starter Gear
Old 06-06-09, 06:22 PM
The large gear that the smaller gear on top of the starter mower engages to start the engine is missing all of its teeth, I ordered a new part for it but does anyone know how to replace it? Its an older model 15.5Hp Briggs ride on
Old 06-06-09, 08:23 PM
cheese's Avatar
I believe the new gear will come with an instruction sheet. You have to drill the rivet head off, punch the rivets out, remove old gear, and install the new one with the supplied bolts and nuts.
Old 06-06-09, 08:25 PM
You have got to be kidding me haha im taking it somewhere there is no way i can do it
Old 06-06-09, 08:28 PM
cheese's Avatar
Why not? Got a drill? It's easy.
Old 06-06-09, 08:36 PM
Yea but I dont wanna break anything, and how do I even get to that gear
Old 06-06-09, 08:38 PM
cheese's Avatar
Oh... I thought you had that part off already. Maybe you do want to take it to a shop. You have to remove the engine shroud and remove the flywheel to get to the gear.
Old 06-06-09, 08:44 PM
Do you think I can do it myself, im currenty having issues with my truck that is taking the majority of my cash flow haha
Old 06-06-09, 08:50 PM
We really have no idea if you are are capable of doing it. The task does require some tools and mechanical savvy, if you do not feel comfortable tackling it talk to a service shop.
Old 06-06-09, 08:51 PM
I no im just asking if its something someone with a little experence can do..... not really looking to spend 100$ in labor on this thing
Old 06-07-09, 10:20 PM
cheese's Avatar
Someone with mechanical ability and some tools can do it. I can do the job in 30 minutes or less at my shop.
Old 06-08-09, 10:19 AM
My uncle used to be a mechanic he is gonna come give me a hand when the part comes in, from what im reading online... am I gonna need a special tool to remove the fly wheel?
Old 06-08-09, 09:14 PM
cheese's Avatar
A steering wheel puller works well.
Old 06-09-09, 06:07 PM
I think the better question is is it possible without the tool?
Old 06-09-09, 07:38 PM
cheese's Avatar
Yeah, but you risk damaging parts. You can put the flywheel bolt in until it's 1/4 inch or so from bottoming out, then have someone lift up on the flywheel while you hit the bolt downward with a hammer. Done correctly with a sharp blow, this usually gets the flywheel to come loose.
Old 06-09-09, 07:45 PM
they way i remove it is i use a prybar used for prying off hubcaps on cars and go around the flywheel till it pops loose. you also risk breaking the flywheel that way.
Old 06-09-09, 11:03 PM
cheese's Avatar
Or the charging stator, or the engine block.
Old 06-10-09, 09:22 AM
So im pretty much outta luck with doing it myself? Im just gonna have to pay a ton to have someone come do it for me
Old 06-10-09, 02:06 PM
BFHFixit's Avatar
You do not need much pressure lifting up to remove it as cheese suggested.
You should notice a slight bit of up and down movement in the flywheel. You only need to hold the flywheel "up" so the shock of the hammer strike has room to move the crank "down" a very small amount...
I use a prybar on a safe place on the flywheel and just enough pressure to keep it raised...as cheese said, with a targeted sharp blow, it will pop off usually.
Old 06-10-09, 05:08 PM
Alright ill figure it out lol, does anyone know anything about y the clutch pedel is sticking down? I gotta lift it up with my foot to move, alright tried to spray some wd40 in there didnt do a thing
Old 06-10-09, 10:15 PM
cheese's Avatar
Probably the clutch return spring is off or broken.
  #21
Old 06-11-09, 07:32 AM
How can I fix that? Is it just that side panel that the pedal goes into
  #22
Old 06-12-09, 01:42 AM
cheese's Avatar
It's a long spring that goes from the transmission belt tensioner arm to the front right corner of the mower frame.
  #23
Old 06-12-09, 08:31 PM
I have the mower opened up now, how do i access that spring?
  #24
Old 06-13-09, 12:06 AM
cheese's Avatar
What is your model #?...................
  #25
Old 06-13-09, 06:06 PM
Never mind about that I am having someone come out to work on it ill just have them look at it, not gonna spend alot givin that I can just lift it with my foot
  #26
Old 06-14-09, 07:27 AM
How can I get a pull start on it
