Governor problem with honda gx160 generator
Old 06-10-09, 02:10 PM
Does anyone know how the governor arm attaches to the governor toothed wheel inside the crankcase.
Old 06-10-09, 07:23 PM
There is a paddle on the end of the shaft that rides against a plastic 'thumb' on the end of the pin. If the engine suddenly started over speeding the gear has likely failed, not uncommon in Honda's.
Old 06-11-09, 10:53 AM
Thanks for your reply. The plastic "thumb" on the end of the pin has broken into pieces. Do i need to replace this "thumb" or will it work ok without ? Does the paddle rest on top of the "thumb" or at the side ?
Old 06-11-09, 07:21 PM
The plunger definitely needs to be replaced, the paddle rides on it.
