Kawasaki FC290V 14HP hard start when hot.
Old 06-19-09, 12:19 PM
I have a John Deere 240 garden tractor with a 14HP FC290V that starts and runs great except that if I turn it off when it is hot it will not restart. I took out the plug (new last month) and cleaned it and blew out the spark plug hole. I got it to start but it seemed like it was flooded. I don't want to do this every time I stop. The carb has a small solenoid at the bottom. I can hear it click when I turn on the key. I am not sure what it is supposed to do.
THANKS
Old 06-19-09, 05:39 PM
BFHFixit's Avatar
Off the top I would say you may need your valve lash adjusted. If you have fuel and spark and it only happens with warm engine and without looking up your engine specifics that would be my guess. Does it seem to crank a bit faster and maybe puff like it wants to start?
If so it is not a major operation and if you have some ability, you could do it yourself.
Old 06-19-09, 08:04 PM
cheese's Avatar
Received 17 Votes on 15 Posts
I agree with BFHFixit. I've run into a couple of these old Kawis that needed a valve stem grinding.
Old 06-22-09, 05:54 PM
I thought maybe it was a carburetor problem but if you guys say it is valves then so be it. I am going to tear the engine down for a valve job.
Old 06-22-09, 09:06 PM
BFHFixit's Avatar
Should be easy to check the clearance by just removing the breather cover.
