Quantum 6.5 pressure Washer by Troy Built
Old 06-20-09, 11:05 AM
Question Quantum 6.5 pressure Washer by Troy Built
I was given a Quantum 6.5 pressure because it was blowing oil all over the place. Actually someone threw it out and I came along at that time. I took it home looked it over and found that the problem was it was overfilled with oil. I placed all new gaskets (just to be safe) filter and a part that broke on me while repairing it. I also clean the washer inside an out. I need to know if this washer needs to have oil added to the gas like you would a lawn mower. it's a 2003 model and no rubber bulb for the gas (the one you need to pump about 4 or 5 time to start some machine)
I would appreciate all help.
Old 06-20-09, 02:46 PM
31YTech's Avatar
No, It doesn't require oil in the fuel.
Keep a eye on the oil level, If it smells like fuel the carb float valve isn't working properly. This could be why the oil level was high when you got it.
