Oil Leak
Old 06-22-09, 05:32 AM
Oil Leak
I have a Craftsman 4 cycle push mower. The engine model number is 143.006502. It looks like it is leaking around the Breather Assembly.As soon as it starts you can see oil running down the side. Do I just pry that off and put another one in or is that a sign of a different problem. The mower runs fine except it leaks the oil. Last week I had to much oil in and when it started it blew out a lot of smoke. I drained some of it out and it ran fine after that. I had the oil leak before that. I'm just letting you know about the over fill because I've over filled it before and it didn't blow smoke out.
Thanks Dave
Old 06-22-09, 09:55 PM
cheese's Avatar
I had one or two leak up there as well. I replaced the breather if I remember right and fixed the problem.
Old 06-23-09, 06:05 AM
Hello Cheese,
I tried to pry up the breather cover but it looks like I'm going to have to get a gear puller to take off the flywheel before I can take the breather off. Do you think I should replace the whole breather ass'y or will just replacing the breather cover stop the leak?
Dave
Old 06-23-09, 09:08 PM
cheese's Avatar
I don't recall...It's been a long time since I saw one leaking from there. You do have to remove the flywheel. It seems like I replaced all of it to be sure it was fixed.
