Lawn-Boy Mower Shoot Gas Out Exhaust
Old 06-24-09, 04:36 PM
Hi,
My father's Lawn-Boy mower, 10323, is shooting gas from the exhaust on start up. After a while it runs ok, but it will so the same thing again the next day.
Any ideas what this is or how to fix it?
Thanks
Old 06-24-09, 08:00 PM
hopkinsr2's Avatar
How many times do you prime it & do you have it in the choke position @ the same time while starting it??? It should start with choke OR primer,, But both is overkill... Also check for spark when starting,, These Lawn-Bowys are famous for ignition modules going bad,,, Good Luck,, Roger
Old 06-24-09, 08:42 PM
cheese's Avatar
Sounds to me like the needle is leaking and allowing fuel to seep into the engine while it is not being used. Once you get it started it burns it all off then floods again after you shut it down.
Old 06-25-09, 06:35 PM
Thanks so much for your help. My father is going to look into the needle.
He wants to know, "Is there any chance it could be related to the valve? Do you think it's worth trying to fix?"
I know he changed the carburetor. Could that have contributed to the problem?
Thanks again! I really appreciate your help!
Old 06-26-09, 01:54 AM
cheese's Avatar
No, it wouldn't have anything to do with the reed valve. It's the inlet needle valve in the carb.
