Briggs and Stratton 17 HP oil blown into carb from breather
Old 06-25-09, 07:34 AM
Hello.
I have a 2000 Ariens 1742 EZR mower with a Briggs engine model (17HP) 311777 with overhead valves. Under load (blade engagement) there is some serious oil blown into the carb from the breather. I have changed the oil and filled it with the correct amount. I have also just replaced the breather which did not correct the issue. It also seems like exhaust comes out the breather as well. I have read a bunch of posts that talk about bad rings, gaskets etc. Are there any tests or procedure I can try to determine what the problem is before I take it down? Any information would be greatly appreciated!
Thanks in advance.
Old 06-25-09, 08:19 AM
You can do a compression test to determine if you have compression loss from the combustion chamber into the crankcase = cracked head, rings, blown head gasket.
If this started suddenly, it's likely a blown head gasket. Rings would be a slower process and likely would involve some oil burning.
The most conclusive test would be a leakdown test. I think I would have a shop do that one for you.
Old 06-25-09, 09:01 AM
I checked the compression. It get up to around 90 PSI pretty quick. After I stop cranking the guage bleeds down to zero fairly quickly. (within a couple minutes) I also notice pretty strong suction and blowout on the dipstick tube with oil spitting out if I dont cover it while cranking. Not sure if that is normal.
Old 06-25-09, 09:26 AM
BFHFixit's Avatar
Sounds like your gauge may not be working correctly.
I agree that a leakdown test is the way to pinpoint the problem. You might pop the valve cover and check clearance and valve operation.
Old 06-25-09, 06:37 PM
Most likely the head gasket let go between the cylinder and the area where the push rods pass thru very easy to remove head , break will be easy to see, common probelm with b/s ohv
Old 06-26-09, 07:53 PM
Thanks, I will check out the head gasket. I am hoping its not something more serious like rings or a complete rebuild!
Old 05-07-10, 11:08 PM
same
Hello I got the exact same problem did you end up fixing this?
Old 05-08-10, 09:59 AM
Classic head gasket problem on this engine. Cold compression test may not show it but the oil in the air cleaner is standard. Gasket is under $10.
Old 05-08-10, 08:10 PM
cheese's Avatar
Agreed.
Added this line to meet minimum character requirement for a reply
Old 05-08-10, 08:16 PM
BFHFixit's Avatar
min ?
Old 05-08-10, 08:19 PM
cheese's Avatar
how'd you do that? I get a min 25 character limit.... heck, and I'm a mod...
Old 05-08-10, 08:23 PM
BFHFixit's Avatar
lol
PM sent
