murray 6.5 power washer
the fox's Avatar
06-28-09, 07:17 PM   #1
hello i just got this gas pressure washer from my father the problem is i can get it started with the choke on when i take it of the choke after it been running for like 1 min it will shut off but if i take the cover off it to expose the top of the carb. where the spring that hooks on the the throdel lever is and i make the spring pull tighter and start it with the choke on then quickly take it off the choke it runs fine does that mean i need a new spring? thanks for any info.
cheese's Avatar
GA
06-28-09, 11:01 PM   #2
No, it means the carburetor is in need of cleaning. Take the bowl off and clean the bowl nut and the inside of the carb.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
the fox's Avatar
06-29-09, 06:57 PM   #3
ok thanks ill try that do i need to remove the carb
cheese's Avatar
GA
06-29-09, 08:44 PM   #4
Not usually. You can remove the bowl and clean it and the bowl screw without removing the carb. Usually this is good enough, but if it still doesn't work right, you may need to pull the carb off and clean it better, running a wire through all passages to clear them from obstructions.
God bless!
rajagiri3's Avatar
06-30-09, 12:43 AM   #5
ok thanks for your tips ill try that do i need to remove the carb
