Lawnmower Help
Old 06-30-09, 09:25 AM
TheOaf's Avatar
Lawnmower Help
I have a Scotts Push mower 3 in 1 mulcher, I only use the mulch. (I don't have model # or anything, I bought it refurbished, but the guy said it was about 5 yrs old)
The problem is with fuel I assume...I push the primer a couple times and pull the cord, fires right up runs for a second or two and then dies. I have to repeat this 5 times or so until it stays running. When it does stay running it seems to run sluggish I guess or at lower RPM's than it should or just weak.
I just go anywho and it will constantly try to choke itself off and sputter etc.
What would you suggest?
SHould I start with the vent cap? Trying to do whatever I can to not have to take the tank off etc.
Old 06-30-09, 12:41 PM
We really need to know the engine manufacturer, engine model, type code usually found on the metal engine shroud just above the spark plug or on a metal tag above the muffler. If it is a Tecumseh you do one thing if it is a Briggs you do something else, however it all has to do with the carb. Have a good one. Geo
Old 06-30-09, 02:13 PM
indypower1's Avatar
Regardless of the engine, it sounds like the carb needs a cleaning.
