Flow thru bolt kit for A.R power washer pump
Old 06-30-09, 10:18 AM
I'm replacing the flow thru bolt kit that mounts the unloader to the A.R. pump. Do I need to lubricate the O rings with anything? If so, what should I use as a lubricant? Anything else I need to know about replacing the bolts - looks pretty easy.
Old 06-30-09, 11:07 PM
cheese's Avatar
You can use vaseline, or silicone o-ring lube available at pool supply stores. It's not absolutely necessary though.
Old 07-01-09, 04:55 AM
Thank you for you're reply. I think I have some silicone grease.
