Weedeater Featherlite SST25
Old 07-05-09, 05:42 AM
Howdy......I've got a Weedeater Featherlite SST25....she stopped running......I cleaned the carb and filter screen and fule lines.........she will start and run now, but when I depress the Throttle Trigger....she stalls....what have I done wrong............any ideas????????????
BudMan
Old 07-05-09, 06:30 AM
hopkinsr2's Avatar
A lot of these little carbs are kinda pickey... Did you put a kit in it with the gaskets & diaghragms?? If not,,,I think you should as they get stiff over time & not pump fuel (especially with todays fuels). Make sure the engine is well sealed & the cylinder is tight to the crankcase & all the other parts are tight... Make sure there are no holes or soft spots in the fuel lines.. If you take the carb off & find out what kind it is, the carb manufacturers have excellent manuals on there websites... Roger
Old 07-05-09, 08:57 PM
cheese's Avatar
Open the mixture screw(s) a bit if it has one or some have two.
Old 07-11-09, 05:34 AM
Weed Eater Won't Stay On
Each time I start my Weed Eater is starts, runs for a 30 seconds with smoke coming out, and stops. Starts again does the same thing, and after about 3 times, it won't start again. Any ideas???
Old 07-11-09, 05:52 AM
When you hit the no start, hold the throttle wide open with the choke off and try to start it. It may take a number of pulls. If it starts before your arm tires out, it's likely flooding that's behind your problem.
A diaphragm kit may take care of it.
